lookin to make between 500 and 550 hp
But the SO pump is just so much easier!
The thing I don't like about the HO trucks is the higher compression ratio. So those going with higher HP, can benefit from a +.020" gasket.
Dave
Just run a hair less timing and that should basically be a wash.
You are talking static compression. And with the tight lobe centers and early valve closing events, dynamic compression DOES make a huge difference!
And pulling timing out of any engine further hurts it. Loss of bottom end and fuel economy to start.
And since we really can't finely control the timing yet, it's not a great option. The easiest thing is to lower compression slightly, keep the timing and allow that motor to spin!
Dave
Even better would be to give a proper cam that can USE that extra compression! Spread those centers already! Exhaust prob opens way too late, and intake closes way too soon.
Anyway, what the cam card for a stock ISB cam?
I have degreed a few stockers, but I don't have my notes. Probably tossed them. I had designed a few cam profiles but I lost interest.
Closing the intake later and spreading the lobe centers do help. Unfortunately, it often comes at the detriment of idle quality and some loss of low rpm torque. However, it can be made to work. It's tough to dial in the cams with a regrind as you start getting into the base circle to "make them right".
The best thing would be to start with a wide lobe blank and grind from there. And then produce off that cam. So we are just kinda stuck with the basic can profiles that are currently available. This is why most of the top racing/ pulling guys run low compression. There is only so much that can be done with the standard profile. And none of this goes into ramp profiles, opening/ closing rates, lobe width, tappet inertia and the list goes on and on. Just so much to consider when dealing with so much weight.
But again, dropping a touch of compression has huge gains. Especially with the SO pump. Typically, we look for more compression when we have a lower dynamic compression ratio. This recovers cylinder pressures, but usually at a higher RPM.
Dave
Dave
poindexter1
07-24-2009 01:41 PM
5.9Excursion
37
10-27-2007 11:44 AM
1Coyote
06-15-2006 12:59 AM
mr T
08-05-2005 05:50 PM
