Longer trailing arms? where?
I would like to install some longer trailing arms for my 2001. I have 2" spacers and the wheel sits a little too far back after the lift. I would like to move it back to where it should be. Who sells these arms? Thanks
![](https://www.dieseltruckresource.com/pics/data/500/2255002007-FULL.jpg)
www.dtprofab.com/dodge.htm
Yah, Those are very nice, I'm not sure I want to pay that much for them, I saw another brand somewhere, that were made of square tube. Anybody else have info on these arms? Thanks
Pretty much all the lift companies make longer arms that you can buy seperately. Rancho, skyjacker, superlift............. just call your local 4X4 shop and they can probably help you out!!
~Nick
~Nick
www.solidsteel.biz are in the process of comming out with an adjustable one shortly,check with them.
http://www.suspensionconnection.com
The control arms out of the 3" lift kit will work. I have a set layin here I havent had time to put on yet. The Control arm bolt diameter changed some time around 98-99 so be sure and get your year specific bushings and sleeves out of the kit too. You can drill out the sleeves from an earlier year if you have to. I paid $175 for the 4 arms bushings & sleeves.
Cummins4life, I just called the place you mentioned, and he said it pushes the axle to far forward. When you going to put yours on so I can hear if it works. Use you as a guinea pig
![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
the 3'' tough country lift comes with a 3'' coil spacer and arms for the front if you have a 2'' spacer you could get away with the 3'' lift arms but why not just go to a whole 3'' lift? I just put a 3'' lift from suspention conection on my truck. I put the spacer on the D25 coil for now till I can get a larger coil made and the ride is not that bad. Put it right were it needs to be not to high but higher than stock. I clear my 35 no problems.
Originally Posted by ridofpwrstroke
Cummins4life, I just called the place you mentioned, and he said it pushes the axle to far forward. When you going to put yours on so I can hear if it works. Use you as a guinea pig ![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
Yup they should. I dunno when I'll have the time school and work are keeping me busy. But they came off HOTMOPR 's truck you could PM him and ask. Here is a link to his photo gallery, all of the pictures on the first page, and the first few on the 2nd page have them installed.
https://www.dieseltruckresource.com/...0&ppuser=27352
Originally Posted by getblown5.9
i plan on buying those arms from the suspension connection 4.5" kit, and using them with a set of 5" skyjacker coils...or D25 coils with a 2" spacer
![No No](https://www.dieseltruckresource.com/forums/images/smilies/new1/nono.gif)
Coil Spring Specialties makes a way better coils for about $20-30 more than the Skyjunkers, and you can specify a softer spring rate.
