Lockup switch warning light
Old 01-25-2007 | 07:30 AM
Eskimo's Avatar
I think everyone who has a lockup switch installed has at one time or another either stalled, or come dang close to stalling the engine.
I wanted to prevent that, so I wanted a light that would come on when I hit the brake, but only when the L/U switch was on. Because I used a lighted switch, I already had to run a relay to get the ground needed by the TC.
Off to Radioshack.
Attached is the way I wired the relay...
For the light, the other leg is connected to the wire on the 5-wire brake harness that goes 12v+ when you press the pedal. Lockup switch is otherwise connected as normal.
This is with the lockup switch on (far right)
Then when you hit the brakes, the light between the EGT and boost lights up. It doesn't look very bright, but it's RIGHT in your line of sight and more white than green, meaning it WILL get your attention. I bought the light a while back for another project, I believe it came from Waytek or Del-city, but any 12v light will work.
Old 01-25-2007 | 09:53 AM
CODODGE2500MAN's Avatar
Very impressive
I haven't done a lock upswitch yet, might just get the controller from ats when they do the trans. Otherwise, I'd be doing it, and a light would be a great way to keep from stalling! Thanks for the tip, as I know others will feel too! Very clean install
Old 01-25-2007 | 01:00 PM
Gotlift01's Avatar
Cool idea!! That should help big time on not forgetting to turn that sucker off
~Nick
Old 01-25-2007 | 02:22 PM
rattlerbob5.9's Avatar
Thumbs up light???
Why would you need a light?????? Don't you seem to notice the truck bucking and shaking prior to stalling??? LOL That sure wakes me up i have not stalled it yet --but thanks for the good idea and directions
Old 01-25-2007 | 02:38 PM
dieselrob's Avatar
Good idea. I got enough wires switches gauges and lights allready. Mine wont stall when i leave it locked found out twice. First time it was wet out and just kept pushing the truck scared the crap outa me. Second time was dry out and it actually made the rear start hopping and jumping the tires. Was pretty neat except i had all my windos open and it made a ton of smoke when bogging the motor down and filled my cab. Had to stick my head out the window for a few seconds.
Old 01-26-2007 | 08:00 AM
Eskimo's Avatar
Originally Posted by rattlerbob5.9
Why would you need a light?????? Don't you seem to notice the truck bucking and shaking prior to stalling??? :
And it can already be harmful at that point..
Old 02-05-2007 | 03:29 PM
I agree it is not a good thing when it bucks and shakes i have only had it happen to me twice i can not imagine stalling it or the rear tires spinning as some have OUCH!
Old 02-05-2007 | 04:14 PM
schoust's Avatar
Thanks Eskimo,as soon as the mercury goes above twenty this will be my next mod....
Old 02-05-2007 | 06:57 PM
infidel's Avatar
If you want to get even fancier here's one that will buzz at you
Old 02-05-2007 | 09:23 PM
taken5875's Avatar
not sure but couldn't you also wire it so when you hit the brake it unlocks or are some of you also using itas some sort of breaking device.
Old 03-07-2007 | 08:32 AM
Eskimo's Avatar
I do use it as a very minor assist in braking, and if you had an exhaust brake or were going to add one, you wouldn't have to re-wire the dang thing..
Old 03-07-2007 | 09:50 AM
Eradan's Avatar
I was wondering if anyone would bring this up ... when i wire mine up i'm definitly going this route ... and then i won't have to worry about it.
Old 03-08-2007 | 12:54 AM
Teddy Bear's Avatar
I know there is a way to wire up a TC indicator light that comes on when the TC is locked, but is there a way to wire up a light that comes on ONLY when the lockup switch is on?
cowboykilla235
02-17-2013 03:02 PM
93dieselZak
06-16-2011 06:10 PM
JQmile
09-15-2010 10:43 PM
genesis
11-07-2008 04:24 PM
Cowboy_Customs
05-06-2008 09:39 AM
Quick Reply: Lockup switch warning light
