lockup ???
lockup ???
This is my first post, and my first Diesel, so I'm a little new here...
I followed the diagram to hook up a lockup switch on my '01, but it doesn't seem to do anything other than let me know when the TC is locked by the LED light on the switch turning off.
I hooked it up to B11 and ran it into the cab to a rocker switch, then grounded to the metal frame under the dash. (I also hooked up the jumper at the relay).
The light on the switch shows when it's on until the TC locks up like it normally would, then the light goes off and it doesn't stay locked when I let off the go pedal.
Thanks in advance for any help..
If you followed these instructions,http://www.tstproducts.com/Torque%20...p%20Switch.pdf it should work.All you need to do is ground the B11 wire with a simple switch.B11 sends 5 volts to ground.Sounds like you have added a 12 volt source.If so?Dont think it will work.
Angry Johnny
08-23-2016 05:01 PM
93dieselZak
06-16-2011 06:10 PM
