Lockright in Dana 80
Old 12-08-2005 | 10:18 AM
v8440's Avatar
Originally Posted by CTD NUT
You can't tell the difference without removing the diff cover. With the cover off it is simple: The Plok spider gear cross pins run on a set cam-like ramps that are visible from the outside of the carrier - the Tlok does not have any of this and the fixed single cross pin is pressed into a round hole in the housing of the carrier.
The cams are what vary the preload on the side gears and clutches, ramping the preload up and down as required. This system drastically increases available clutch loading when required and slackens it off when it is not required. This almost infinitely increases the life and performance of the Plok when comparing it to a unit like a Tlok which is assembled with a fixed amount of clutch preload that wears down over time (or quickly if abused) which in turn will allow for more and more slippage until the LS no longer functions.
Does the trac lock not have any small gears in it? The reason I ask is, when I busted my dana 80 a few weeks ago, there were pieces of small gear in the bottom of the housing. Would the presence of small gears (not ring or pinion gear) rule out one or the other of the two factory lsd possbilities?
Old 12-08-2005 | 12:21 PM
CTD NUT's Avatar
Both the Tlok and Plok have spider and side gears.
Old 12-08-2005 | 01:52 PM
v8440's Avatar
I'll have to pull the cover off and take some close up pictures then. I suspect it's the traction lock, simply because it failed.
Old 12-12-2005 | 01:39 PM
ridofpwrstroke's Avatar
I didnt know the difference in limited slips. That would have influenced my decision. I have a lock rite in my ford 9 inch and it works great for what I need it for. DONT PUT IN A DETROIT if you are using it for the street. They are built tough, no doubt. The shockload will not break the locker, it will break everything else that works with it. Imagine if you could rotate your driveshaft a half turn before it engages, then a half turn when you let off. It will break things. Just how long before it does is how you use it. THey are great off road, and thats about it. I have seen what one does behind a cummins on the street and it dont look pretty. Even in a dana 70.
Old 04-09-2009 | 01:58 PM
SkyHarborCowboy's Avatar
Here is my question to Randy's Ring and Pinion:
I have heard that the (For my 99 Dodge 3500 DRW 35 Spline Dana 80) a Dana P-lok is actually a re-badged Trac-Lok instead and that I would need to order a Dana 70HD P-Lok and have the ring gear holes upsized to the Dana 80 size to get an actual P-Lok. Can you clarify the issue for me and tell me how much the labor costs to have you enlarge the ring mounting holes?
Thanks,
Joe
And the Reply:
The Dana 80 p/l has been discontinued, you may be able to adapt a d70hd p/l BUT the ring gear will only be retained by the bolts not the pilot on the carrier, The ring gear will stick out over the edge of the p/l and it is definitely NOT recommended. We will not machine a d70hd p/l to work in the Dana 80
Allen Booher
Account Manager
Randy's Ring & Pinion
Phone: 425-347-1188 ext. 5570
Fax: 425-355-1529
E-mail: bbooher@ringpinion.com
So what is the true answer? Any actual experience with installing a Dana 70HD Carrier into a Dodge Dana 80 Rear Axle? Which shops are willing to perform the machine work necessary to make it work at what cost?
Thanks,
Joe
__________________
Old 04-09-2009 | 11:37 PM
Dglass89's Avatar
i have 3.55 gears in my truck and i just bought a dana truetrax and i love it, engages smooth and its reliable and price isnt too bad i would reccoment it to anyone
Old 04-10-2009 | 01:49 AM
rage_blue's Avatar
If you do a search on the dana 80s there are some threads about restacking the clutch plates. I plan on doing this next time i service my diff. I might even try to put some extra plates in to make it lock harder. But I'm trying to get a spool like diff with out spening much money.
Old 04-10-2009 | 02:41 AM
1-5-3-6-2-4's Avatar
rage blue.....I have a welded D80 carrier for 3.55 ratio sitting on the garage floor doing nothing.
Old 04-11-2009 | 06:51 PM
Fergavs's Avatar
1-5-3-6-2-4
Count me in as being intrested. That would be perfect for my 90. Let me know.
jimjawz
35
04-07-2005 10:26 AM
Mechanos
01-22-2004 01:45 PM
matthopp
11-21-2003 05:49 PM
mcevins
07-03-2003 03:06 AM
Stamey
04-18-2003 11:34 PM
