LMC HD headlight wiring, Highs stick on with fog lights??
looks like im just full of problems latley. I just got the wiring harness installed tonight from LMC for both the high beams and the low beams. i have a sport with the fog lights. with the fog lights off it works just like it should. as soon as i turn my fog lights on if i turn my brights on then back to low beams the high beams stick on and i end up with every single light on. as soon as i turn the fog lights off then its fine. if i had to i guess i probably could add a relay to block my highs from coming on when my fog lights are on but i dont see why this is hapening. you guys got any ideas what the cause might be???
upon further examination it looks like the outside bulb 9007 is switching from high to low beam fine its just the 9004 (inside bulb) is hangin on high beam but only with the fog lights. any of you electronic guys have any ideas???
well i kinda found a fix. there must be somthing wierd with the stock switches. i switched the pins for the 9004 bulb and pluged it into the 9007 connector on the other side. so now it works ok but the 9004 bulbs come on with my low beams but its the low beam part of the bulb. i will have to see if that is ok and doesnt blind on coming trafic. otherwise i will remove the pin for the lows and it should function like stock.
Crazy_Farmer
04-19-2010 04:19 PM
2007 5.9
20
12-09-2008 03:19 PM
fjbiker86
37
12-09-2007 07:29 AM
