Liquid to Air CAC
Liquid to Air CAC
www.frozenboost.com , check out the 1200hp DIY kit. Why couldnt this be rigged to work on our trucks, price is certainly right, compared to 3G plus for some other systems ive seen!
Where are you planning on putting the intercooler at? The engine bay is pretty full already. You could put it behind the bumper but you would have to run new intercooler tubes. Another idea is put it on driver side between the engine and fender, but it will be tight. I really wonder how good it would be at cooling the inlet air at high boost with flows. Thats the real question. I would think that it would be better for cars as they hardly run more than 2-30 psi of boost for racing, on the street the most would be around 10psi.
70 psi max water pressure..... i would assume that air should be higher but you never know.... they don't list that..... air will compress perty easily.... water on the other hand dosen't.....
matego
05-21-2008 03:05 PM
