Line-X bedliner questions on prepping
My truck is starting to show its age on the bottom of the doors, not any holes, just surface rust. I am gonna be getting the bottom of my truck sprayed with Line-X [grey color]. I know how to do bodywork, but I am wondering if I should just sand blast it & coat it in primer before taking it to the Line-x guys. Do they do all the prep work & rust treatments before spraying or is that my responsibility?
Talk to the the guys you plan on doing the LineX. Most of the time they rough up the surface a little so it bonds better. I personally like my Rhino but its all personal preference.
I was going to get the rhino, but my bro has it & it is chipping off along the edges of his tailgate where it meets the bed. Also along the edges of the bed & along the rails. It also has a really rough texture & I want a smoother texture spray. I've been trying to call that shop all week, but haven't had time or they are closed. I usually get a busy signal when I do call, just figured someone here would know.
I used to work at linex and when trucks get sprayed all we do is hit the area with a d.a. sander then wipe it off with lacquer thinner. If your truck has a little surface rust no problem but if the rust is deep and there is pitting or holes you will want to fix that yourself.
Mark2008
05-28-2013 07:37 PM
Out Back 4x4
18
08-21-2007 05:35 PM
JoeDiesel
26
09-21-2004 05:07 PM
MedicShawn
02-26-2004 11:21 PM
