Lift and pusher pump confusion duhhh =(
Do I want to add a pusher like a Holley, carter, BD, FASS, Airdog, ect back at the tank to FEED my stock LP, or to bypass it?
I would prefer to not spend that big dollar stuff.
A pusher pump is just an add on pump that you mount on the frame rail to help feed the LP. FASS and Airdog make kit that bypass the stock LP and fuel filter if you want to go that route, but it is more money than just adding a pusher pump like the holley or carter to help supply fuel to the stock LP.
If you spend under $300 you'll be able to replace the stock fuel system with a Walbro system and not have to worry about it again ... or you have the option of replacing $160 pumps every so often, maybe annually, laying on your back getting your hands dirty ... your choice!
If you decide to go the Walbro route, check here.
Flow_Master
01-29-2010 09:29 AM
SuperiorRam
08-23-2007 05:28 PM
Big Smoky
03-23-2006 12:11 PM
midwestdually
15
12-17-2004 08:52 PM
