lift pump upgrade final decision!! any last suggestions
ok, i think i have made up my mind finally!!! I have the juice with attitued on the way and knowing i need to up grade my fuel sustem, i have decided to go with the FASS 150 due to the fact that i like the filtration and water seperation. I have done a fair ammount of homework and that looks like the bedt route for me.
The only thing i have not been able to find out is how many hp's will the 150 handel because i do not want to have to upgrade it later.
A am going to do a big like kit as well with a gauge.
Any last suggestions before i make the buy!!!!!!!!!!
thanks
Aaron
thanks
Aaron
I think you're making a good decision. I don't remember the high HP number, but it's way up there. I know Rowj has run close to 600 and has had no problem. I'm sure Dan will let you know as soon as he sees this.
You'll max your injection pump out before you'll come close to the limitations of the 150gph. Also, last I checked, the FASS replaces all of your fuel lines and fittings so you won't need the big line kit.
I Just put in a Walbro pump sys. from Wideopen Diesel I did a lot of research on a lot of different sites before I made the jump. Both are great pumps and you can not go wrong eather way. Hey just my 2 cents. And good luck Al
Did you check this pump out?
http://www.wickeddiesels.com/eliminator.htm
I'm probably going to go with a cam and a mechanical pump.
thanks
Aaron
thanks
Aaron
You can actually run the 150/95 on a VP truck and be just fine. As Blue said...you will see the limitations of the VP before our 95 GPH system on an VP-44 injected engine.
wcialrlter
04-17-2008 05:51 PM
mudder500
25
03-19-2008 10:09 PM
NJMurvin
01-20-2004 08:42 PM
