Lift Pump Questions
Old 01-05-2006 | 01:28 PM
brutus99's Avatar
Lift Pump Questions
I'm new to this forum, have been watching things for awhile, lots of great info here! My question is fuel pressure at WOT is less than i want to see 7psi. Does the bully dog fuel pump kit replace the stock lift pump at the engine mount or is it designed to be relocated by the tank? do you use the bully dog has a pusher pump to the stock lift pump? thanks in advance!
Old 01-05-2006 | 08:04 PM
scottsjeeprolet's Avatar
I'm running the Bully Dog system and it puts a Holley Blue on the frame next to the tank and runs big fuel lines up to and through the stock LP.
22psi idle & 15psi WOT
this is a nice kit and affordable from JEGs $235
good luck have fun
scotte
Txwelder
12-18-2023 03:35 PM
realsquash
08-19-2005 09:52 AM
Txwelder
05-19-2005 07:10 PM
JackRAK
12-07-2003 12:04 AM
015speed
05-14-2003 10:27 PM
