lift pump/holley blue - fuel pressure
Old 07-28-2006 | 06:29 PM
blackdiesel's Avatar
Registered
ok im running a holly blue with my oem lift pump. I get good pressure, never below 13 at WOT. and at idle it has my 15 psi guage pegged. however the fuel pressure needle is VERY erratic when i run at WOT. it will jump from 13 - 16+ very very rapidly, over and over again.
I thought it might be my lift pump going bad, so i unplugged it and i get 12 psi at idle and 0 at WOT with just the blue, so that's a no-go. i get the same results if i unplug the blue and just run the lift pump. so thats not it either
i remember when i first put the blue on with the fuel pressure guage. All was smooth, then it started acting up.
And yes, i have a valve in the line, and yes it is almost shut completly off.
Is anybody else's truck do this? is there a fix?
Old 07-28-2006 | 08:20 PM
scottsjeeprolet's Avatar
You might have toasted your guage pegging it like you are. I have a 0-30 and i have the same set up check my sig. I get 23 idle and 15wot. if you don't believe me look in my gallery.
Old 07-29-2006 | 01:30 PM
Registered
well, dad has the in-tank pump and his guage does the same thing. (only at 6 psi at idle and 0 at WOT! ) it moves very rapid also. And it has never been pegged.
anybody else?
Old 07-29-2006 | 04:08 PM
Registered
update - changed the fuel filter (10,000 or so miles) and now i cant pull it off of peg!
77machomopar
12-02-2009 08:53 AM
AlCorr
114
02-11-2009 03:32 AM
JME07Vegas
50
02-16-2008 11:04 AM
Texaschevelle
26
11-16-2007 09:08 PM
brutus99
15
01-13-2006 10:07 PM
