Lift pump harness
Old 12-01-2004 | 05:01 PM
Moose10's Avatar
Lift pump harness
What is this "lift pump harness trigger wire extension" used for? It looks too short to be extending anything anywhere. Is it to use a 3rd gen lift pump? If so why?
Thanks !
https://www.dieseltruckresource.com/...cat/500/page/1
Old 12-01-2004 | 05:48 PM
ratsun's Avatar
Its used when you put a 00-02 lift pump on a 98/99. The 98/99 LPs had about 6" of wire with the plug atached where on the newer ones the wire harness is longer and just plugs into the LP. So when I replaced my LP I had to use the jumper as my wire harness was to short to reach the pump. Hope this helps.
Old 12-01-2004 | 06:43 PM
Moose10's Avatar
Gotchya !
TankerIP
02-26-2011 09:17 PM
betsycam
10-08-2010 10:57 AM
mulepackin
07-13-2006 06:49 PM
dctoner
05-11-2004 12:07 AM
