Lift Pump Failing?
Lift Pump Failing?
My FP is 10 at idle and 4 at WOT. It used to be 17 at idle and 6 at WOT when the truck was new. It's a little over a year old and has 29K. Should I pursue a warranty replacement or go with an aftermarket replacement? Is there a pump that can replace the stock lift pump?
Re:Lift Pump Failing?
If it were me, I'd go with warranty replacement as often as I could till the warranty ran out.
Then I'd look into an aftermarket system.
By then, all bugs should be worked out and a great bulletproof system will be available.
No point in spending money on something that might fail, let Dodge spend its money for a while.
It's their fault they fail so often, maybe they'll learn from their mistake.
phox
phox
[quote author=phox_mulder link=board=7;threadid=19671;start=0#msg185053 date=1063671406]
[/quote]
Well, at least it's a noble thought!
[/quote]
linetrash75
09-23-2005 08:32 PM
Asher
07-19-2005 01:36 PM
