lift pump/edge comp
lift pump/edge comp
my lift pump does not seem to be up to the task of handling the edge comp I can not even run on L2 with out pulling my fuel PSI to 5-6, pressure is a good 12 at idle and with the comp off I pull 7-8 at WOT. Any one of some links for some upgraded pumps? thanks
5 psi is considered minimum "adequate" FP for WOT with the VP, though, most people want to see much more at WOT........Start doing some searches on LP's - there is TONS of reading on that subject hear.......Holley pushers, FASS, FASS II, Scotty Smart fuel line kits and on and on........
most of the vendors here and TDR offer 'bolt on' complete kits. it's cheaper to gather the parts yourself, but i thought it was easiest to get it all in one box, i went with the Diesel Dynamics kit. You'd be surprised at ther difference with the pusher pump and a larger line kit (like the Scotty's smart line kit)
Re: lift pump/edge comp
Originally posted by shoe
......some links for some upgraded pumps? thanks
http://www.dieselpp.com/
http://www.piersdiesel.com/Products.htm
RJ
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
