lift pump advice?
lift pump advice?
I just installed a fuel pressure light on my mom's truck (stock 02 auto) and it needs a lift pump. It will always be stock as long as she owns it so there is no need for anything fancy. I think I will probably relocate the pump using Geno's kit. What pump do you guys recommend? A factory replacement? Holley? Aeromotive? Thanks, -Evan
I got the new version pump from O'Reilly. No problems so far. It's a completely new design over the OEM pump, but mounts to all the stock hoses and in stock location without any mods or extra parts. $150
i wish she would go with FASS, but wont spend the money. What are your opinions on the less expensive ones? For the ones that arent a direct bolt in, is wiring them pretty basic and straightforward?
The frame mounting removes vibration and heat from the engine, and it allows to pump to push fuel, rather than pull it from the tank. Pumps like this are designed to push better than pull. Using a relocation kit like the one from Vulcan or Glacier Diesel gives you a longer wiring harness that is plug and play, larger line from the tank to the injection pump, which reduces restriction, and an array of fittings and bracketry to mount it. The AirDog system is on sale now, too. You may want to look into it.
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 11:15 AM
