Lift pump
Lift pump
Im having a total blank here.... Where the heck is the lift pump on a 98 24v 3500 2wd? Also we just bought a Holley Blue and it flows 110gph is that good enough for the truck?
Thanks
Sean
Thanks
Sean
Try following your VP44 inlet back. This will take you on a much needed tour of your 24valve fuel system. THe first thing you will encounter is a large cannister looking outfit. Its your fuel filter cannister. The inlet line on this is on the back side, it should lead you to your lift pump. THe LP should be bolted onto a bracket thats connected to your block.
BTW, All this is happening on the drivers side.
Originally posted by Mcmopar
Why do you have your mom's and dad's vehicles on here, I think they belong somewhere else. In case you forgot this is a diesel site.
Yukon Dodge
18
07-01-2004 10:08 AM
Puke
05-22-2003 12:18 AM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
