lift pump
Old 04-27-2006 | 02:28 PM
johnh's Avatar
Smile lift pump
if you want to move your stock pump off the engine to the frame and get rid of two banjo fittings (on pump) tap the inlet & outlet 12x1.5 metric threads to 1/4 pipe and use a 3/8 hose barb....works well , u could tap to 3/8 pipe but i think you would have to drill it out more... with 1/4 pipe, drilling is not needed
Old 04-27-2006 | 11:24 PM
kelownadiesel's Avatar
Why wouldn't you just do it right and buy a vulcan kit,bigger lines and ditches the banjo bolts
Old 04-28-2006 | 08:24 AM
Silverjay's Avatar
Sounds like it saves ~$15 in fittings.
Txwelder
12-18-2023 03:35 PM
Txwelder
05-19-2005 07:10 PM
Yukon Dodge
18
07-01-2004 11:08 AM
Puke
05-22-2003 01:18 AM
Haulin_in_Dixie
47
11-17-2002 10:30 PM
