Lift kit
Lift kit
Can any of Y'all tell me what has been done to the front suspension of this poor truck ?<br><br>Pics can be found here <br><br>I know the rest is not looking too good, but you should have heard the engine run and have felt the auto shift. <br><br>TIA<br><br>AlpineRAM
Re:Lift kit
That looks an awful lot like a Skyjacker lift.
The red springs, red control arms, and red upper control arm relocation bracket are Skyjacker.
Also looks like a Skyjacker trac-bar extension bracket.
And a Skyjacker sway bar extension bracket.
The steering stabilizer seems to be in the wrong place?
The steering linkages almost look like they are bent in places they shouldn't be bent.
And the sway bar joint looks a little bent, or missaligned?
(in the pic showing the driver side from the front, with the trackbar extension bracket)
The pitman arm looks like it is factory length, hence the steering linkage being at such odd angles.
My Skyjacker came with a longer pitman arm to fix that problem.
Looks like a lot of oil dripping of the steering box as well.
I don't see an add-a-leaf on the rear springs, and can't see the lift block, perhaps they just have a taller block?
Is this the truck you're looking to buy perhaps?
Is the Y'All from the southern part of Austria?
phox
phox
Re:Lift kit
Thanks phox !
Do you have some pics where I can see what it's supposed to look like ?
I have been looking at this truck today..... as the vendor said.. some bodywork, but mechanically top...
Actually the steering box is not only leaking but the shaft is bent some too
Yup, there were things bent and sum whatchummacallits welded where they shoudn't be ;D
And no, the Y'all was imported- maybe I should order some more of them, seem to be running out- anybody want to swap some Umlaute for some southern slang ??? can offer Ä's and Ö's. But htere is even more- some Ü's will be added to your delivery if you call right now
AlpineRAM
AlpineRAM
Re:Lift kit
I don't currently have a front view of mine, but I do have an "over the tire" pic of what all those parts looked like new.<br><br>I can snap a front view and post it for you, for now here's what I have.<br>Taken from the passenger side.<br><br>I'll snap some more either tonite or tomorrow morning and post them.<br><br>phox<br>[img width=600 height=450]https://www.dieseltruckresource.com/yabbse/gallery/albums/userpics/4%20inch%20parts.JPG[/img]<br><br>
Re:Lift kit
Doug: Thanks, I do not think it will be necessary- won't buy that heap anyway.<br><br>It's interesting what some people do to these innocent trucks :'( <br><br>AlpineRAM
Re:Lift kit
Actually its Jerry (or phox).
Doug is the "exhaust tone and volume" guy :
Probably a good idea to stay away from that truck.
Don't want to gamble on front end stuff, especially with the problems a perfectly good Dodge front end has.
(DeathWobble, Tracbar, steering box, etc)
phox
phox
Re:Lift kit
Ooopsie, sorry Jerry , it was a little after 1 am in my neck of woods. :-[ <br>The main reason why I'll stay away from this truck is the price. I do think that any attempt to repair by a definitely incompetent mechanic actually decreases the value of a vehicle.<br><br>Thanks<br><br>AlpineRAM
sgtdiesel
25
06-26-2012 02:37 PM
mudder500
07-29-2007 12:27 PM
doomgaze
04-13-2006 01:21 PM
lucey
04-21-2005 09:53 PM
