Which lift coils to use?
caper......mine went right in. No grinding necessary.
BA Ram....Coil Spring Specialties http://www.coilsprings.com/
Originally posted by caper
I got the CSS springs sittting here in front of me. About to put them in.They weigh a ton. They told me I have to grind the bottom of the spring where it goes into the seat because the 1 inch wire is too big for the seat.This will make me very unhappy if I got the truck tore apart and have to break out the mini grinder. Any one have experance installin them????
Custom Suspension - http://customsuspension.com/store/pr...roducts_id=753
Coil Spring Specialties: http://www.coilsprings.com
Originally posted by Dr. Evil
I think there is some confusion here...
can I put that in my signature (quoting you of course Dr. E)?
~Rob
Installed my CSS custom coils (from the Kansas company) on Saturday with new Bilstein 5100s. 5% softer and 2" taller were my requirements.
Wow... awesome... much improved... love it... want to go drive down some rough roads just to impress myself some more...
The CSS springs were a bit over 19" tall in the box and I took a pic of them against the OEM springs which were #39's BTW and the new springs were just about 2" taller than stock. We used a spring compressor to bring them down to 17" so they would slide into the perches. The 1" thick wire did NOT cause any problems... just slid right in.
The ride is great... I can hit expansion joints and bumps and definitely feel a difference. If I had to do it all over again, I may even go softer... maybe 10% softer than the stock 38/39 I had. But I love it and expect to be happy for a long time.
One thing to note, the height of my truck after install was actually about 2.25" taller than before. I really didn't want anything over 2", but I am hoping they settle the quarter-inch over the next year or so. Also, my axle was pulled to the drivers side no more than 1/2 inch. I am running the stock trackbar, but eventually I think I will upgrade to the Thuren trackbar which I could adjust.
Thanks to Cowhand who shared lots of information with me on spring / shock rates and steered me to these coils at this rate from CSS.
No pics yet, hope to have what I took developed and scanned in within a week or two.
Steve
Steve
I am running the Skyjacker coils, and theya re not the best. I was considering getting rid of those coils and haivng a custom spring builder bend some up for me at my rates, and everything. I was then going to get rid of the trac bar altogether by fabbing my own long arm kit for the front of the dodge. I can build a Long arm kin in a few days, and wll never have to deal with the trac bar again. If there is wnough triangulation, I am good ot go.
When driving, I get all aorts of snap crackle and pop fron this truck.
Dima
Dima
What do you know now Phox that you didn't know when you bought your lift? I have been running my for almost two years now and I have had no problems whatsoever. They're not sagging, no squeaks, and ride decent in the front. The rear is stiff but that's pretty normal for truck. That Kore stuff is overpriced unless you really plan on running your truck across Baja at 120mph lol. I'd just skip the whole beat the hell out of my $50K truck thing and buy a buggy if that is what I was into...
Really the only thing is the harshness of the ride.
I don't want a cadillac like ride, but something a little less kidney beating for daily driving.
Custom coils, longer arms, rear leaf pack instead of the add-a-leaf, better shocks.
I still recommend the Skyjacker kit for the first time lifter though.
phox
phox
Dima
Dima
Already talked to several fabricators about it, and unless you are prepared to go to a fore/aft drag link like the solid axle Toyotas or old Dodges, it won't work. Might have a hard time converting the steering, the fore/aft drag link setup was used on leaf sprung trucks, no coil in the way.
Much easier and way more economical to go with a good aftermarket track bar.
After 4 1/2 years, it's sitting in a pile with my stock ex manifold and stock tie rods. Poly bushings and heims are shot.....when I pulled the control arms off, the metal sleeves fell out of the poly bushings.
I second what phox said....SJ is one of the better off the shelf kits. DT Products is coming out with a 4"-5" kit pretty soon, complete with arms, coils, Bilstein shocks, and a re-designed track bar. It should be competitively priced with the upper end SJ kit, and performance and strength wise it will blow the doors off of any bolt on kit out there.
Originally posted by Cowhand
My SJ kit was fine for the first two years....after 3 I started having alignment issues and the springs started sagging. After four years I couldn't keep it aligned for more than a week or two.
duke,
What are you running for a track bar?
Keep an eye on the poly bushings/sleeves, my bushings hardened up and they actually had more slop than the heims. They should be cheap to replace when the time comes.
