Lifespan of High performance injectors
So I am looking at purchasing some Mach formula one injectors with 60k. Do these puppies have a lifespan that will need to be maintenanced at some point? Can I get 200k on injectors with the same quality service as when newer? Does anybody have over 100k on there high performance injectors?
Thanks
Thanks
They are a high quality injector. I'd be surprised if they did not go the 200,000 miles you ask about.
Just don't know anyone that has stayed with the same set for that long without upgrading to bigger!
What size are you looking at?
RJ
RJ
Mach 2.5's may be older tip technology, depending on when Mfg'ed... but still quality product. IF price is right I would install and never look back. If close to new price...I'd do the 1.6's you mention in your sig.
Super B should be perfect for your setup... w/ the injectors.
RJ
RJ
