Level Kit and Now I Bounce
Got a level kit put in on my '94 4X2 and I did expect some change in ride. I'm bouncing pretty big up front going over even minor bumps. Is this to be expected or should I look at the shocks?
Hey, it looks nice, though. And now I can fit 285s.
I did the same, but with springs and shocks. It sounds like you need to look at your shocks. I can give you the #'s for the KYB MonoMax I used, if that's what you're in the market for ... great shocks! No bounce here, solid as a rock!
Originally Posted by AAmeeting
Sorry to go off track but can I lift the front of my 3500 dually? I cant find anything for it. Would your kit work with mine? I would love it to sit higher.
there are several companies that make leveling kits for you truck.
theres a few that make the spacer but my favourite is the skjacker d-25 springs replacement. by far the best way to go but change your shocks at the same time or you'll have buddys problem ^
I went to 4wheel parts and they said nobody made a kit for it. The guy looked in books for about 20 min. Skyjacker you say... I hop over to there web site.
I made a left at an intersection all torn up with construction and the road was kinda uneven. Shoot I was bouncing so bad I had to pretty much stop in the middle of turning to get it back under control. Not good!
Thanks for your help! I need all that I can get!!
With the 2" overstock height in the front, the shocks I had to use were the KYB MonoMax #565102. I'm not sure if your setup will be the same. If you're not looking at the KYB's, use the part number to cross reference to another shock ... maybe even a cheaper shock, like a Monroe, just to see if it works out ... not to say Monroe's are bad, don't get me wrong! The KYB's will cost you in the mid $50 ea. range.
Okay, the kid at Murray's gave me some Monroe shocks, as they did not have KYB in stock. I 'm kinda wanting this done quick so I can get the 285/75/R16 Coopers on. Man, I hope this works!! I would think anything will be better than the stock shocks from 12 years ago (or so I assume they are).
routerguy99
11-18-2003 10:29 AM
