Lets See Those Gauges!
I got my gauge mount from diesel manor and also got the matching paint but didn't use it. If you go this route you'll need the long pyro leads. There is a lip that fits up under the head liner and the mount just sticks to the windsheild with 3m scotch loc.(mushroom tape?) I replaced the 2 small pieces that came with the mount with a 6" strip because when I stuck it up there I forgot to cut out the window tinting and it came loose, don't make that mistake. Now I think I would have to put both feet against the windsheild and pull to get it off! It's been stuck for several years in the Florida sun with no problems.........bp (forgot to say you'll have to lower the mirror some,easy to do)
Standard A Pillar w/ H2O/Meth 'on/off' switch and green LED for when it's injecting.
Don't use/need the Tweeter
Dash Pod for FP/Secondary Turbo Boost/ Differential Temps
RJ
RJ
Crossy's son
08-11-2015 07:50 AM
Firstgenfanatic
06-06-2011 05:25 AM
diablo1
27
11-10-2009 09:46 AM
Kman9090
29
12-06-2007 06:43 PM
