Let the bombs begin... now which injectors?
Old 12-10-2007, 03:53 PM
sledneck1's Avatar
So after a ton of hard work up til now i finally have some cash to fix up my tranny and do some bombing. I'm pretty stoked, today i ordered:
Goerend VB, TC, apply straps, levers and misc internal goodies that dave recomended. (TC setup to work with the mods below)
Vulcan pusher pump system (i have a couple carter pumps to use for now)
Smarty (YAY!)
fuel pressure gauge (i already have boost, trans and pyro)
hx40 downpipe
HTT HTB2 62/12
my plan is to sell my quad. xzillaraider and put in some big sticks. I talked to the guys at HTT and they told me to go with a 62/12 instead of their HTBG 57/12 with 100hp injectors (jammers 3s) Would it be safe to go with some Jammers 4s and still be able to tow (4-8000lbs) or should i stick with the jammer 3s? This truck is going to be my daily driver and i use it mostly for hauling two snowmobiles around the mountains. Once in awhile i use it for towing the odd boat or travel trailer.
I'm going with injectors and a smarty because i'm tired of fueling boxes like my edge comp and now my quad. crapping out and needing to be sent back for repair! This is going to be some fun bombing, my truck has been stock for a couple months now since my last box crapped out!
Old 12-10-2007, 05:10 PM
DMcPherson's Avatar
I have gone through a lot of boxes and I love my quad. I use a modified hx35, (hot) and 120hp injectors and with the box off it tows great, with it on oh man. its my favorite combo so far. and I have used a comp, tst comp, smarty, ez, and I think thats it.
Old 12-10-2007, 05:32 PM
Fishin2Deep4U's Avatar
You have some options for injectors.
I am running Mach series sticks and love them. There's a whole list of honed injectors out there as well.
I recommend doing lots of research before you buy anything. And try to drive something setup in a similar fashion.
Oh, whatever size injector you think you need, increase to the next available size. You'll thank me later.
Dave
Old 12-10-2007, 05:42 PM
C2O
C2O's Avatar
what mods do you have done to your stocker? just exh housing and some porting or did you go further than that?
Old 12-10-2007, 05:52 PM
DMcPherson's Avatar
its an early hx with a 14cm housing with the divider drilled, and a banks gate. it cooks with the 120s and the quad but with the injectos and va plugged in or with the quad on 1 it works great
Old 12-10-2007, 06:23 PM
MikeyM's Avatar
By "cooks" are you talking EGTs or the hauling of ****?
Old 12-10-2007, 08:54 PM
C2O
C2O's Avatar
i think he's talking high egt's. with the quad on kill and 120 inj. is a warm combo. van aaken not so much
Old 12-10-2007, 08:55 PM
C2O
C2O's Avatar
its an early hx with a 14cm housing with the divider drilled, and a banks gate.\
yeah thats about standard for the HX.
Old 12-10-2007, 08:58 PM
afoulk's Avatar
You'll probably run cooler, maybe even make a little more power with some better quality injectors, like Mach's, DDP's, or I.I.'s. The jammers are hard to beat price wise though.
Old 12-10-2007, 10:28 PM
sledneck1's Avatar
So bottom line what size of injectors to i need to light the HT3B 62/12 ? Do i need a minimum 120hp injector? I just want to make sure i'm throwing enough fuel at the turbo!
Old 12-11-2007, 09:31 AM
sledneck1's Avatar
My goal is right around 400hp but i will sacrifice quick spooling and lower egts for all out power. Lots of guys must run this turbo, whats your setup?
Old 12-11-2007, 09:36 AM
DMcPherson's Avatar
yeah cooks as in temp. I think its a 14 housing anyway. the quad gets HOT
Old 12-11-2007, 11:34 AM
Stock size WG housing for the HX35 is 12cm. Did you change housings? Is it wastegated?
Dave
Old 12-11-2007, 11:49 AM
DMcPherson's Avatar
yeah the housing was changed. it is wastegated.
Old 12-11-2007, 12:32 PM
C2O
C2O's Avatar
for 400 hp you can use a ps62/12
Quick Reply: Let the bombs begin... now which injectors?
