Last chance to chime in. Advice Needed.
I finnally decided to bomb my virgin 94 auto 3500 ctd. My goal is 300hp reliable without high egt's. I have an appointment next friday with Mass Diesel to have the folloing done: KDP, 3k GSX, #5 fuel plate, 215 injectors, and pump timing. I have already added a multi disk billet converter and shift kit. I am also installing a 4" exhaust. I am using this to haul my drag car to and from the track, 24' enclosed trailer about 7500lbs loaded. I dont have plans to upgrade the turbo unless I have to. What should I do about delivery valves?
Thanks
Herb
Thanks
Herb
You can add some 181's which are stock in the 215HP pumps or use 191's, whichever you feel like or can get cheaper. It is a slippery slope once you start this stuff, you never feel satisfied! lol Enjoy your new-found power though!
You should have a really good base once they tweak it, you'll hardly be able to tell it's the same truck One thing I forgot to mention is that if you overshoot your goal HP for being able to tow without excessive EGT's a valet switch is a quik easy way to fix that problem. With mine opened up (full fuel) I can nearly peg my pyro in the upper two gears, with it closed (full valet) I think my max EGT is 1000*, but it still feels like its got the low-end to rip the Titanic in half.... again, lol.
Will the shift kit protect your tranny? Are you sure you need to use a #5 plate? It's not recommended for a stock tranny and you are doing other mods too. I don't think you need a #5 along with injectors. Your fuel economy will probably go way dow too. Maybe a 10 or 8?
CentralCalRam
03-27-2013 02:26 PM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
y-knot
13
10-23-2003 08:32 PM
