largest box fueling only box?
if you are after more fuel send that comp back for the drag upgrade . so it will fuel on 5x5 till 3200 insted of the 2700 it fuels to now. or maybe its time for bigger sticks
I bigger fueling box isn't going to do you any good if you still have the stock ho pump. If you still have an HO pump you could do bigger injectors. You could switch to a HRVP and then get a bigger box. As far as boxes that change fueling without tapping the wire the only one I know of is the smarty.
Registered
alright heres the story. i just got my truck back from the dealership, p0216. go figure. but a year ago, i had them replace it so it should have been under warranty. so i took it in and they said that it probley wont be covered and that ill have to shell out another 1800 bucks
so, if i can get a fueling only box, that dosent void the warranty, and stack it with a smarty, and maybe mach 4's or mach 6's and a htb2, ill be set.
I'd second that call Chip and ask him about it 888 472 7373 ext 1, he's a really good guy.
And that largest fuelin only box, I'd have to go with tst powermax3 comp, or bluechip fms or redline. And i'd get the smarty for timming.
Bryan
Bryan
Registered
Originally Posted by displacedtexan
I say you ought to get a HRVP-44 from Blue Chip. Their warranty covers wire tap boxes.
There are no "large" fueling only boxes that DON'T tap the wire. About 65hp is all you can get without tapping the wire.
If that's what you're looking for, Smarty and Mach 6's should get you over 500hp with an aftermarket turbo
Chris
Chris
Bryan
Bryan
Just teasing
Registered
Chris
Chris
400 has been done with a Smarty and Mach 4's, I'm pretty sure 500+ was hit in the last couple weeks with a Smarty and 6's
That's the direction my buddies 02 HO is heading...as soon as I start paying him for the work he does to mine
Chris
Chris
