Large injectors without a box?
Assuming one had the air, would not having a fueling or timing box(boost fooler only) limit the level of injectors that could be run.
I am seriously thinking about some 125+ hp injectors, a boost fooler, and a different turbo/'s.
Re:Large injectors without a box?
After about 100hp injector, I would suggest that you at least run an Edge EZ or DD TTPM to match injector to pump delivery.
But, the 125's with a boost fooler will work fine.
You just wont have the low end that a box will provide.
--Justin
--Justin
I have a set of BD5 injectors, and a comp box. Most of the time when using these injectors I run with the box off, the boost fooler still works and it runs good, but I am a huge fan of the comp box and would do it before injectors.
[quote author=BLUTIC link=board=7;threadid=23735;start=0#msg223716 date=1071503712]
Not to change the subject too much, but will my Power Puck that is on my 2000 work on a 2001 truck?
[/quote]
The MAP plug and parameters are different so the Puck will not work properly, but if it is the older canbus style Puck it will give some fueling.
[/quote]
What are you going to try? Which injectors, clutch and which turbo I mean? I will be coming through Ft Worth on the 23rd if you need anything.
I was just re-reading things and realized that you will need a boost elbow so the waste-gate operates later than 20-22 lbs.
You have a hx35 turbo and there are other exhaust housings to use that will reducw heat. Go bigger!
I ran about a year with III's (100hp) and no boost elbow, I did notice more power down low. I also didn't hook up the comp I bought at the same time because the III's caused my clutch to slip and I needed it to last a while. Mine never overboosted with just the III's, never set an overboost code either. The wastegate seemed to be able to handle it. Now without the extra boost, I wasn't able to fully use the extra power, but going from stock to III's I never noticed. I dyno'd around 290rwhp with just the III's, K&N, stock everything else. Now I have the comp hooked up, SBFE, Pschotty II, straight pipe, and I can see around 36-38psi. I also dyno'd around 450rwhp, but I can't tow shoot.
lol
lol
5.0 Mustang Man
38
09-19-2008 03:01 AM
04ctd
10-05-2006 08:27 PM
pcburnout
09-07-2005 08:25 AM
600 Megawatts
20
03-21-2005 01:35 PM
amartinson
09-12-2004 10:15 PM
