Knock of a second of a 24V
I need to make my 98 24 valve a little bit faster. It turns around 13.8 s now launching at 16 psi boost.
its got:
Jammers stage 3
Edge juice/attitude
II SPS 62/14 turbo
Intake/Exhaust
Suncoast transmission
It strugles and smokes a lot to spool up with the tight 3disk converter now.
But barely smokes at 44 psi boost.
Thanks for any input.
its got:
Jammers stage 3
Edge juice/attitude
II SPS 62/14 turbo
Intake/Exhaust
Looks like you just need a lil more injector, like Jammer 5's or Mach 4's, and a looser converter if you cant lite a 62 very well with yours.
Brett
Brett
already broke an output shaft once. didnt look at the boost gauge launching that time!! i guess it was over 20 psi.
How would the low end smoke from the mach 4's compare to jammer 3's?
we live at high elevation, and i prefer less low end smoke, before turbo spools
I'd consider good used Mach inj.
How much faster would an Adrenaline be? thanks for the input yall!
There are brand new mach4's, still in original package never used for 750. These normaly cost 900, says sale pending but may be worth looking into. TDR website classified ads.
I went from an Edge J/A to the Adrenaline and the smoke off idle has decreased a lot. It seems like the Adrenaline lights the turbo faster! Those Jammers are very smokey injectors to begin with. A set of Mach 4's would be a big improvement! Stack a Smarty with the Adrenaline and Mach 4's and you'll be very close to where you want to be!
HappyGA
15
10-16-2006 08:21 AM
Hoss
30
10-03-2006 02:57 PM
