A kit to improve coolant flow - no more dead-ending at the rear of the block!
#31
We installed mine with just the head off. The plate required a small amount of grinding on the bottom to allow for clearance against the bellhousing.
I have NO idea what kind of difference, if any, it made, though I imagine it could only help things.
I will be plumbing the kit into the upper radiator hose that connects to the thermostat, and regulate the pressure to 30-35PSI per Enterprise engine to prevent freeze plug blow-outs.
#32
So how is this working out for those that have it??? Any freeze plug issues?
Was there a difference in cooling over the summer? I know you said you couldn't notice a difference in the last post but it was also february.
What's up with the adapter? Do you take the freeze plug out or modify it?
Thanks
Thanks
icrider
19
05-14-2010 08:08 PM
Need95-00CTD
01-09-2009 08:07 AM
