Keeping your BHAF cool
I was just reading a thread on a Scotty 11 install where they cut a hole in the firewall to get cooler air. Could a person not use this same idea if he made sort of a funnel shaped air tube from the firewall over the end of the BHAF. Would this not direct cooler air to it as you are traveling down the road or street. It was just a thought that I had.
I would be interested in others ideas of keeping their BHAF cool in addition to using a heat shield.
I've been thinking the same thing...I have read here (and I can't remember who it is that has it) that you can run some 4" PVC from the front airdam up to the air filter heat shield to funnel in cooler air. There was a big argument about the merits of this because the turbo heats the air anyway which is why we have the intercooler. I think it would be fun to try and see how it affects power and mileage. Besides the ductwork would be cool. I think the only major issue is how to make it all work, keep it away from the turbo and the oilfilter. Seems like a fun project though. Hopefully someone who has seen it or done it can weigh in.
I did the PVC to behind the bumper on my 04.5. It worked excellant and seems to have brought the MPG up sum. My filter minder barely budges now where it used to hit redline after one pull on a fresh fleetgaurd filter! The truck is much happier and the passengers can tell a noticable difference in sound/smoke reduction. I cant comment on EGTs as the 600 engines run freakin hot. If my 95 runs 600 EGTs then the 600 is usually running 950.
I have been meaning to give the PVC airbox a try on the 95 but havent figured out a way to run it yet. Looks like 3" will work.
BTW I thought you guys had plenty of cold air availible in kanada =P
When I installed twins, could no longer use the Scotty II, but I left the hole open. Plan on testing with and with out, but have not as yet.
Just makes sense to me that the ram air effect from the cowl can only help! It's all directed at the filter...so I see no need for the "air tube" you mention. IF it's competing with any hot air coming around the heat shield....I bet the cool, ram air will win!
The heat shields must be worthwhile, all Mfg's are using them. Have one on your BHAF?
RJ
The temperature drop will help quite a bit.
Theres many calculators out there where you plug in your intake temps, turbo effeciency, intercooler effeciency, and see the output temp.
The intake (pre-turbo) temps due have say in the final temps after the intercooler.
Get some dryer hose and run it to an ice chest of dry ice on your passenger floorboard
Originally Posted by Ph4tty
Sounds like a good idea, but dunno if the results would be worth the effort.
Originally Posted by rjohnson
No stupid questions!
RJ
RJ
I have also thought about making a shield up front by the intercooler to direct air behind the headlight and down the fender like the original air box uses. I think if the fender was blocked just past the outlet to the filter that it would have somewhat of a ram air effect.
Has anyone tried this idea?
I had a 1998 Tacoma one time, the box the filter sat in had an elbow that jetted out the passenger side fender. There was a peice of plastic covering it from the tire area. It should be cooler air than the engine compartment.
.... When I installed twins, could no longer use the Scotty II, but I left the hole open. Plan on testing with and with out, but have not as yet.RJ
Test showed no difference in max boost...with or without the hole!
Proper test will be to measure air intake temps, at the air horn! Will do so...when I can find the time
FWIW... this test was done, a few yrs back, with BHAF vs Stock air box (outside air) and the difference in the air horn was 5 degrees. May not sound like much but I suspect it is... in HP!
RJ
mikmaze
08-13-2006 12:26 AM
loid mongol
05-19-2006 10:35 PM
DuaneWKKC
10-18-2004 02:29 PM
Varmint
03-26-2004 10:40 PM
