Just purchased an Edge COMP Drag box!
Old 07-06-2005 | 04:55 PM
CTD_Neil's Avatar
I am the winning bidder of an Edge COMP Drag box. I got it for less than $500! Next is the turbo which I believe will be either a B1-2 or an HTB2 unit. Then I have to replace the boost and EGT gauges since the ones I have are made to work with the Banks computer
What kind of power do you think I will be able to put out with these upgrades and what I already have in sig below?
Old 07-06-2005 | 05:49 PM
sleds's Avatar
450ish would be my guesstimation.
Old 07-06-2005 | 08:51 PM
CTD_Neil's Avatar
Hey Sleds, Thanks for the reply and guesstimate. What HP are those jammer 5's?, do you like the HTB2 turbo? does it keep your EGT's in check? thanks
Old 07-06-2005 | 09:18 PM
CASMOKIN's Avatar
Im getting my drag put in too, cant wait
Old 07-07-2005 | 08:39 AM
signature600's Avatar
I know where you could get a full B1...PM me for details
Chris
Old 07-07-2005 | 09:35 AM
JDGnut's Avatar
With the Drag comp.. DDIII's and stock HX, you'll be about 420-430... (Maybe a little more) If you change turbo's you'll pickup a bunch more... I had some issues with the low numbers in my sig... they were having some problems with the dyno that day..
This is the Comb I recommend for my Customers.. its seems to be the best of both worlds.. Performance/Towing/Price... To tow.. turn the box off or on level one... Its a good setup..
Bryan
Old 07-07-2005 | 10:13 AM
PourinDiesel's Avatar
475hp-500hp depending on dyno's with the 5's. Maybe even a little more.
Old 07-07-2005 | 10:25 AM
sleds's Avatar
ctd neil
The jammer 5's are rated at 150, but I got a set thats closer to 200. The htb2's are awesome turbo's and yes they keep egt's decent with this much fuel. The b1's are a great turbo also.
Old 07-07-2005 | 12:39 PM
CTD_Neil's Avatar
thanks, I just need to choose a turbo and part with the cash, then I can run with the BIG-ger boys.
Old 07-07-2005 | 12:40 PM
Beast2B's Avatar
as far as turbos, go with a wastegate if you're gonna use a B1-2, full B1 would be my first choice knowing what i know now.
13jy831
02-25-2011 08:45 AM
lvmknsmoke..
08-13-2009 11:59 PM
mx684
13
07-24-2007 08:52 PM
CTD2001
84
08-13-2006 11:33 PM
rockjeep73
03-25-2005 04:34 AM
