Just order this any good
any good for $207.45
This is what you have been waiting for - AEM BRUTE FORCE Premium Intake System for the 94-04 Dodge 5.9L Cummins Diesel.These system enhances the performance of your new Dodge by 19+ Horsepower! Every AEM air induction system is individually tuned in length and diameter, and features the highest standards of construction—AEM even guarantees them for the life of your vehicle. Every AEM air induction system is either C.A.R.B. exempt, or pending C.A.R.B. exemption (50-state legal).
Features:
One-piece, four-layer cotton gauze filter (reusable)
Constructed of CNC mandrel-bent 6061 aluminum with TIG-welded fittings and brackets for maximum durability
Stainless-steel heat shield included
Mountings hardware and reusable gasket
Free filter service kit included
Easy 20 minute installation
Includes Filter service kit
Limited Lifetime Warranty
Ummm. Isn't this a little like putting the cart before the horse? You have ordered it and then ask for our opinions?
Suggestion: Make some tests with your stock filter and then repeat the tests with the new filter. Report on DTR what you find.
You tell us if it is any good.
The only thing I don't like about the looks of it, is the shiny metal tube attached to it. The problem is you want to drop EGT's not make em go higher, and metal conducts heat
There is a reason that Dodge makes the air inflow tube out of something other than metal. Beyond that it looks cool
Administrator / Scooter Bum
So if I put 2 of 'em on, will I gain 38 HP?
I'd like to see a set of Dyno sheets on the before & after.
19 HP by changing a filter (other than a totally clogged one) on a turbo diesel would be a pretty good feat.
jmccart
08-02-2007 12:35 AM
AggiePhil
35
01-09-2006 02:33 PM
dealseeker
15
12-17-2002 06:43 AM
