Just installed 3K GSk. Now has hard starting. Can i adjust the springs to fix this?
I put a 3k gsk in my truck. Its now harder to start with the idle at the same place, and someone said i could back off the spring retainers one click. Is this right? Im gonna move the plate soon, and ill do that while im in there if it will help it. Thanks
Eric
Eric
The idle setting may now be too low. Press the throttle down and get it started, let the throttle return to idle, if it dies then you need to adjust up the idle screw.
Well, when i first got the springs in, it idled way to high, so i idled it back down to where it was, and its harder to start than it used to be still. It idles plent high, and ive been driving it like this close to a month. Its just harder to start(cranks longer).Thanks
Eric
Eric
Yeah, it start fine if i give it just a little throttle, but i dont like having to do that, so i think i might back off the springs a hair. Thanks
Eric
Eric
GTSDave
17
08-24-2010 12:34 AM
wvopowered
04-23-2008 06:43 AM
abc4yew
03-15-2007 11:55 PM
fishin fever
04-22-2006 03:00 AM
Got Smoke?
10-26-2004 03:57 PM
