Just got the new turbo
if your serious about getting rid of turbo lag... you can inject nitrous into your exhaust manifold on launch or just throw a shot of it in there whenever you want it spooled. U'd have to have way more $$$$ than me to do that though, cuz don't expect that turbo to last very long haha
The shop air pressure should be quite a bit higher, actually. Keep in mind that the TIP will be trying to push that WG open as well as the boost pressure to the actuator.
On the bench, you have no TIP at all, so you should actually look for almost DOUBLE the desired pressure. So if you want it to open at 45psi, it should open on the bench at almost 90psi.
This is based on the assumption that TIP is roughly equal to boost pressure, and BOTH are acting to open the WG. Hence, a 2:1 factor in my estimation.
Bench test your stock charger's actuator set for ~20psi and you'll see it takes a LOT more to open it all the way up with just shop air-- almost double.
Pinch the the wastegate hose and see if you can get over 40lbs. If not you definitly have some boost leaks if you do get over 40 shorten your arm length but make sure you still get plenty of gate travel after shortening it.
black smoke certainly isn't a fuel problem, anybody considered that its a 64mm turbo with a 14cm housing and is going to be super laggy no matter what compared to a stock turbo?
Dale M
03-05-2011 04:40 PM
LFD2037
03-18-2008 12:55 AM
jester0401
35
02-20-2007 12:15 AM
bhoff1175
06-07-2006 11:19 PM
