Just got the new turbo
I just got home and found new ps64/65/14 had arrived. I am gonna put it in in the AM. Any advice or tips for install. Thanks
Not really a break in needed but I would baby it a couple heat cycles and make sure the turbo to manifold bolts are tight after it cools to dead cold (overnight). Some guys say baby it for a 100-200 miles to let it loosen up before it gets much soot build up but with big injectors good luck on that one.As far as priming dump oil in the top before you put the oil line on and you should be good to go.
Use a little squirter bottle, eye dropper, pipette, etc to push a little oil in the feed hole before you hook up the line and spin the compressor blades with you hand to work the oil into all the bearings and such. We're talking 1 cup of oil or so to do a thorough job. You can actually work some oil in before you even install it through the larger oil drain on the bottom. Just pour in out of a quart bottle and turn the blades to work the oil in.
What's breakin? Just drive it normal and if I were you, I'd do a run to 15, 20, 30psi, so on. Check for boost leaks.
It's a lot easier to adjust the wastegate rod before you install the turbo. If you want to run 45 psi boost, you need to adjust the rod length, by turning the threaded portion to shorten the rod. Then pull the silicone tube off and put a little regulated shop air into the silicone tube. If you set the wastegate to start moving at 45psi shop air, it will start opening at 38-40 psi when installed because the exhaust drive pressure also tried to blow open the wastegate so it opens sooner than you preset it.
If you want 45psi max, set it for 50 psi or so with the shop air.
If you have a boost elbow, it is easy to fiddle with/ fine tune after your turbo is installed so no need to mess with it before install.
I just got it on today and it runs awsome. the power is unreal. my only problem is that its real laggy. from a stop it will black out the sun for about 100ft then just pulls like crazy. what can i do
how much boost you building, and you say you blow lots of black smoke for a 100 feet that must be when you stomp on it but how it just driving are you blowing lots just driving it cause i have 80 horse inectors and i wanna upgrade too 150 sticks but i dont want too be blowing smoke when im not on the throttle so let me know thks
If im easy on it taking off I only get a real slight haze. If I just put it to the wood it turns day into night and the cars are stoped waiting for the sun to come up
