Jumper positions with Edge EZ
I have an Edge EZ and was wondering if it has a setting with the little jumpers for fuel only. I could swear that it has a setting that is for fueling only but cannot find my original paperwork and the Edge tech I talked to said it is timing only with the EZ.
........U can bring up the info on the edge site......I asked earlier on here about stacking chips and the responce was to run the smarty on settings that dont add timing, cause the EZ does........kim..............
Some one should probably back me up or correct me on this, but I don't think there is a fuel only setting. IIRC, setting 1 is timing only, setting 2 is timing and added fuel at 10psi boost, and setting 3 is timing and added fuel at 3psi boost.
My EZ was made in 2004, so it is rated at 50 hp max. The newer ones are rated at 60 hp, but I am at a loss as to how they get there. I should probably just get a Smarty.
Blue Chip says that thier injector pump has the maximum amount of timing that the engine can tolerate, so I was looking to just add some fuel to get back some of the "git up an' go" that the truck used to have.
the older edge ez did have a jumper, and when I checked mine (bought new) it was in the highest posn, if I recall correctly it was only a few hp difference and more for smoke control, I played around with it and found no measurable difference, or smoke difference for that matter
rwhite1
09-01-2012 10:46 AM
12valve@heart
10-12-2007 02:03 AM
mr T
09-22-2005 09:41 PM
