JL Stealthbox opinion
I've been thinking about getting the JL Audio Stealthbox and the JL Audio 250/1 amp to go in to my '99 2500 Laramie club cab in the middle 20 seat and so i've been looking at past threads about them and have been getting mixed reviews. So can anybody give me a straight cut opinion on the box, 12W3v3 that they put it in and the amp. I'm just adding it to the factory system and am just looking for that added bass.
Thanks
-RustyBoltz
Thanks
-RustyBoltz
The one that goes under the front middle seat I'm not that impressed with........it sounds ok but that's about it...just "OK". Now the stealth box that goes under the back seat sounds pretty decent. Not sure it's worth the money but if you are looking for something clean looking and out of the way it's not a bad buy.
~Nick
~Nick
The bigger the box, the bigger the sound. I'm assuming that since you want a 12" sub, that you are wanting quite a bit of bass. This box is probably not for you. It is designed more for a smaller sub (10" or 8") & will sound better w/ a more crisp style of music.
Is there a better option for me. I don't want to remove my storage under my back seat b/c I use every bit of my club cab so the hidden sub in the seat is the way i want to go.
Thanks for the replys.
-RustyBoltz
What other components ar you refering to?
Well I'm not looking to totally blow out my windows with bass, but rather to add some more range to my factory stereo. The only reason that I mention the 12W3v3 is that it is the sub that JL's website states that they put in this box.
-RustyBoltz
-RustyBoltz
I mean you can get a 7" mid to pound pretty good. Generally subs don't need a real clear amp signal, but distortion and early voice coil failure can result from poor amp quality pushing a big speaker.
As far as sub boxes go there are different type of boxes which produce different types of bass. Sealed boxes, band pass and ported boxes come to mind. Sealed boxes produce a nice tight bass but require a stronger amp to push them, while a ported box produces a boomer sound. A nicely tuned band-pass can sound especially good but a usually large in size..
If you're looking for some extra bass to compliment your stock system the JL box should be up to the task. IMO
I like 10's myself because they have a crisp sound w/ a sealed box. I used to like the bigger speakers when I was younger, but my hearing has suffered greatly because of it.
And the rest of my system I'm planning to stay factory.
Dynamat and similar products are meant to dampen and insulate. Highly recommend doing the inside of the doors. It helps alot!
Subs are mainly personal preference. JLs are very good subs. But it all comes down to musical taste. Some like loud obnoxious, others like clean and tight. A great sub that I'd recommend is Boston Acoustic. Their subs have a great sound, tight and clean. They can get loud and rattle windows too. But they are great in super small enclosures. They only require about a .5 cubic feet of space. Which is just slightly larger than the sub itself. If you want good sound out of a small space I'd try these. A G5 and their radiator would pound!
yeah the Boston Acoustic stuff is nice. my dad has a 01 silverado ext. cab with one 10" DB Drive sub under the back driverside seat. Pushes the front door speakers (Boston Acoustic. 50w to each) and the sub (also BA 100w) with a 2 channel Boston Acoustic amp. stock head unit. stock rear speakers and let me tell you. for stock it sounded decent but just that little bit gave it an amazing sound for such a simple setup. not tons of door rattling bass but nice balanced sound that doesn't distort no matter how loud you crank it.
The dual 10" JL Stealthbox under the rear seat sounds better than the 12" center console for sure. I listened to both before I opted for the dual 10. I also got the JL 250/1 to go with it and it sounded great. I sold my '99 and unfortunately it won't fit in the '05. As a matter of fact I still have it... almost sold it for $500 but that fell through so it's sitting in my spare room. I paid almost $1k and it was worth every penny! BTW, don't even consider any other brand of dual 10" under the back seat... I tried the MTX . The JL is hand laid fiberglass, not plastic. If you're ever out this way you can try before you buy, just give me a hollar!
its bad edited by admin box get it and put a punch P3 with a 600 amp. I love mine. Sound better than 2 10 to me
precision1
04-17-2008 12:58 PM
