jammers votes
Old 12-08-2007 | 10:54 AM
txsbigdaddy's Avatar
jammers votes
stage 3,4 or 5 want to be able to run with the quad off and still maintain power and egts then turn it on for the fun factor.
Old 12-08-2007 | 11:31 AM
97' CTD's Avatar
5's Chris (Signature600) Has Full injectors not just the tips for cheap PM him .
Brandon
Old 12-08-2007 | 01:16 PM
wurkenman's Avatar
I have the Stg 4 nozzles. With the box turned off no problem. With it on you will get hot way fast, just watch the EGT's.
Old 12-08-2007 | 03:58 PM
ok i kinda been thinking 4's but was wondering how good they are for every day driving with the box off. also fuel milage have heard tails of gains if they are drove right with a timing box only.
Old 12-08-2007 | 05:13 PM
wurkenman's Avatar
With just the nozzles, it is a night and day difference from stock. I would not hesitate to do it again. I started with just nozzles, because I figured that for the cost o0f just nozzles I could see how they worked before I spent 600 plus on injectors. Then when I crank up the Quad, holy crap. Especially after the turbo upgrade.
Old 12-08-2007 | 07:35 PM
pokapotato's Avatar
I don't like my jammers all that much. They seem to build the power, but in conjunction with the SHO VP44 the engine is very ratty at idle and they're pretty smokey.
heykw's Avatar
5's. just installed mine last night with the box off all is well fyi I also towed a single axle trailer with two four wheelers on it today on level 3 and had no issues
Old 12-08-2007 | 10:40 PM
1qckdodge's Avatar
5s all day, did 497/989 with em.
Old 12-09-2007 | 01:16 PM
can u tow with stock turbo and 5
Old 12-09-2007 | 02:13 PM
GFB's Avatar
GFB
shouldn't be a problem, just don't use a fueling box when you tow.
Old 12-10-2007 | 04:31 PM
2broke2smoke's Avatar
i've got one of the first set of jammer 4's ...
got somewhere around dec of '03 ?
absolutely love 'em ...
have to watch the egts with the box off ... i towed a buddies '91 for a couple of hundred miles .... 'course i had a hy turbo too
BRUISER
NCDTR #18
14
10-06-2008 12:00 PM
Dusty Ratcliff
11-25-2007 04:18 PM
mhuppertz
04-02-2006 11:15 AM
durasmack
03-03-2006 11:14 AM
ramlovingvet
05-18-2004 02:30 AM
