Jammer injector (nozzles only)
Wondering about the pro's & cons of jammer nozzles first I've heard of them, didn;t quite know about useing stock bosch inj bodys
If anyone has opinons they would great
BDC
BDC
Personally, I think this is an interesting way to go. Guys who make their living selling top quality injectors will disagree with me, but for under three bills, you have yourself +150 HP injectors. Yes, you just use your injectors, dissemble them, install the new nozzles and re-assemble em yourself. And if you are nervous about em after you re-assemble them, take em to a diesel shop to check popoff...
As for flow, I was planning on buying a stage 4 set and I think I have a way of testing the flow of them here at the plant. I will let you know the results and see if there is this tremendous flow variation problem that the competitors' salesmen say there is.....
Kevin
Kevin
Thanks for the input, I'm bad about jumpin into things headfirst this is no exception, ordered a set of stage 5's this morning
Am still curious about what parts (orings washers ect I will need to so this) if anybody know
roxxx
02-10-2009 10:30 AM
xOmertAx
20
02-17-2007 09:52 PM
