Jake Brake?
Old 11-28-2004 | 10:31 PM
Buckshotmckee's Avatar
Jake Brake?
I'm wanting to add a Jake, Pac or Banks engine brake. What's your guys take on them? Do they really work? Do they make any noise and if so, what does it sound like? I tow monthly between Los Angeles and Utah and got some pretty good hill climbs. Thanks
Old 11-28-2004 | 10:33 PM
Forrest Nearing's Avatar
you can't get a true engine brake for the 5.9... only exhaust brakes. they do make some noise, but it's not the same as a "jake brake" on an 18 wheeler...
Forrest
Old 11-29-2004 | 12:36 AM
Hemi Cat's Avatar
I've never seen a "Jake brake" on this motor. Only Exh brakes. If you do a lot of driving and pulling heavy loads, especially in hills or mountains, you will save a LOT of wear on the brakes. I highly reccommend it. The sound does change some but mine mostly hisses with a drone change. It will depend mostly on the rest of the exh system.
Old 11-29-2004 | 01:54 AM
Dr. Evil's Avatar
Ive got a Jake - no its not a real jake break but it is made by Jacobs......and it works great (even when not towing or hauling). If you are looking for the "semi" sound - save your money.
I see you have a 4 inch exhaust.....the only brake that will work for you is the US Gear Decelator. Its tru 4 inch and installs in the downpipe. I believe the rest are 3 inch and wont work with your 4" exhaust system.
http://www.usgear.com/dcelerator.htm
Old 11-29-2004 | 02:20 AM
argve's Avatar
I have a Pac Brake Exhaust Brake, works great for stopping/slowing. Especially since I got the #60 exhaust valve springs installed and plugged the hole in the flapper, brings her to an aburb whoa now.
Before it wasn't too bad but not too good either, I actually thought she worked decent before but after getting both those items installed... boy oh boy I'm a happy camper. I can just about shut her down completely and never touch the brakes. I have to remember to at least touch the brake pedal so folks behind me know I'm stopping (could get interesting if I don't let them know what's going on).
Sound wise - as posted before it does not change it much, has a loud hissing sound out the tail pipe, sounds different to say the least.
Now when I flip it on an she's idle'n at first it about snuffs the engine out but recovers very quickly, before plugging the hole in the flapper the sound would change (slight load) and that was about it. Heats up much quicker when I flip the switch in the morning.
I don't think I'll drive another diesel without one, it's just so nice to have backpressure on demand.
Old 11-29-2004 | 10:21 AM
wgingg's Avatar
dont know about your 4 inch system or where it comes in but my pac brake mounts on the back of the turbo with a 3 inch 90 (90ish) that has a flange for the exhaust. if you just bolt to that flange should work but i dont know. i love my brake a also wont own another diesel with out one. need to get the 60 pounders still. i liked the sound it made then when i straight piped it its just a hiss and i dont warm the truck up that way any more cause i have neighbors
Old 11-29-2004 | 10:41 AM
INJECTOR JACK's Avatar
Pac Brake makes a exhuast brake that will fit your 4" exhuast.
Old 11-29-2004 | 11:31 AM
mkubacak's Avatar
I have to agree with everyone else. Once you get an exhaust brake, you wonder how you ever towed without it. I love having it! My only regret is that when I upgrade to twins hopefully next year is that I will have to get a new brake.
Old 11-29-2004 | 03:41 PM
JKM's Avatar
JKM
What is the difference between a true "jake" brake , and an exhaust brake? i thought they were one and the same?
Old 11-29-2004 | 03:59 PM
SmokinFive9 4x4's Avatar
Most twin setups use 5" exhaust don't they? Does anyone even make a brake for that size pipe?
Old 11-29-2004 | 05:24 PM
Yep! as I said before Pac Brake. They make a 5" remote exhuast brake.. A jake brake is a name (Jacobs) for of a company that makes engine brakes. A engine brake is used to open the exhuast valves to dump compression this turn the engine into a brake. You do not find engine brakes on 5.9 cummins they can use a exhuast brake which blocks of the exhuast and builds up back pressure which slows the engine down. It like stuffing a potato in your tail pipe.
Old 11-29-2004 | 05:41 PM
A "Jake Brake" slows the engine by opening the exhaust valves at the top of the compression stroke using the fuel injector cam. It's much more effective than an exhaust brake, and the amount of braking force vs. RPM roughly parallels the torque curve of the engine. An exhaust brake is just a flapper in the exhaist pipe, braking force rises with RPM. A true Jake brake can develop more retarding power than the engine generates horsepower, most exhaust brakes provide 150 - 200 retarding HP. The reason there is no true Jake brake for the 5.9 Cummins is that our engines don't run the injectors off the cam, we use an injection pump instead.
Old 11-29-2004 | 06:28 PM
Thats all true but Cat had a engine brake and a fuel injection pump.
Old 11-29-2004 | 09:00 PM
Rain Man's Avatar
Pac brake
I have been running a PAC Brake since 1999 on my 1999 and it has worked perfect with no problems. When you are empty it will stop the truck in second gear. It has saved me some on brakes as well. I use it as much as I can both empty and when towing. I transport a 17,000lb trailer and it works well when you are hitting heavy grades to assist the brakes. They may not be a true jake brake but they are worth the investment and are easy to install.
Old 11-29-2004 | 09:51 PM
Dr. Evil's Avatar
Thats must be new???.......thats very good news for bombers. The 3" just doesnt cut it.
