Jacobs e-brake
Jacobs e-brake
Has anyone seen the "fingertip" control for the Jacobs e-brake? From what I can gather, it's only available for 2003 models. Check here and let me know what you think. Gauges, brakes, exhaust, edge easy or pulse Way too many decisions!
Re:Jacobs e-brake
Well I'll be a (blankety blank blank). They copied my idea on the two speed rear end switch. That's exactly what mine looks like. I should go after them for patent infringement. They would probably win though since they used a black **** and I used a red one. My red **** looks better on the gear shift. Oh well, another million dollars lost.<br><br>If it works like mine, it is definately worth while if the price is not too outrageous. Mine was about $12 at NAPA.
Re:Jacobs e-brake
Hey DD,<br><br>Tell me more about the NAPA $12 switch. I guess it could be adapted for a brake too.<br><br>Gary<br>
Re:Jacobs e-brake
I have a jacobs on my 02 and would like to know about your switch you put on your shifter. I like that idea better than having it on my knee bolster.
Guest
Posts: n/a
Re:Jacobs e-brake
How many people are interested in getting a Jacobs E brake?<br>The reason I am asking is if I go into my buddies part department and say I got 3-4 guys wanting one what is the best he will do and ship them to us. <br>One the other Jacobs E brake trend I wrote that he gave me a price of $556.88 from a Dodge Dealer. He might do better if a can get a couple more people to get some? Let me know what you think.<br>Ricki
Re:Jacobs e-brake
I had a pacbrake on my 99, it was sweet. Dangit, my new 03 is an auto, there goes that Idea. My 03 Chevy c4500 has one that is a factory installed option and it only cost $300 bucks, it works great.
Re:Jacobs e-brake
[quote author=Cattle Hauler link=board=7;threadid=6132;start=0#56058 date=1035321120]<br>Hope you didn't mind me posting them DD4x4<br>Ricki<br>[/quote]<br><br>No problem at all, if I would have wanted to keep them secret, I wouldn't have posted them here. You saw how well it works when I was out there if the guys have any questions. I just went to the NAPA dealer looking for a switch that would work and look cool. Tried several different ones. I looked through about 12 different switches and he asked me what I wanted. I said something like the old two speed rear end switch. He said why didn't you say that in the first place? Got a whole shelf full of them lying back here. Some vibration will come up the gear shift lever and make it rattle at certain rpms. I solved that by adding a drop or two of Loctite to the point where the shaft goes into the body of the switch. Wala, no more noise. (for a while) I just wired it into the lead to the solenoid under the hood to act as an interrupter switch. Called Jacobs and they said fine. <br>(thinks that is where they got the idea for the 03s)<br><br>Just used two different metal wire loom clamps and a bolt to hold it to the lever. Ground the bolt flush with the nut with my handy dandy little Dremmel tool. Works like a champ.<br><br>Make sure you leave a small loop of wire at the bottom of the gear shift like I didn't do. The wires broke on me at the worst time, coming over Afton mountain loaded to about 23000 pounds. Had to make an emergency stop to fix that for sure.<br><br>Plus, it makes people ask you if you have installed a two speed rear. Some that don't know any better, I say YEP. Then when they look underneath and see that big honkin Mag-Hytec cover with the wires coming out of the rear end (ABS wires), they just know I am telling the truth.<br><br>Coolness......... Drats, foiled again.
Re:Jacobs e-brake
I have the Jacobs on mine and love it, would never do with out. Is there any maintenance requirments on the brake itself, I remember someone saying that the shaft that operates the butterfly needs lubed every now and then, if so what type of lube.
Shilohman
22
11-19-2009 05:13 PM
iflych52
25
10-10-2006 09:25 PM
Nevada
03-30-2003 06:24 PM
rkelso98
03-14-2003 06:15 AM
