It's Dead....I Think!
Old 11-14-2007 | 11:43 PM
efrantz's Avatar
I started the truck this morning and everything ran fine. I drove it about 15 miles and all of a sudden the the fuel pressure dropped to like 12-13 and the truck had low power and then died. I am low on diesel (about 60 miles to empty) so i am not sure if i got air in the lines or if the VP crapped out. I NEED ANY IDEAS. What would cause the fuel pressure to drop like that? The FASS is running good too so I don't know. HELP!!
Old 11-14-2007 | 11:56 PM
Dr. Evil's Avatar
Could it have something to do with this?:
https://www.dieseltruckresource.com/...d.php?t=177246
Do you have access to a scanner?
Old 11-15-2007 | 12:13 AM
hink's Avatar
If you were that low on fuel, that could be the problem. Put some fuel in it, get it re-primed (if that's the case) and see if it will run. They suggest not running these VP trucks with less than a 1/4 tank of fuel. Check your fuel filter also. May have sucked up a bunch of crud with your new FASS.
Apocalypse
07-01-2008 01:09 PM
600 Megawatts
03-26-2008 08:09 PM
Jvenne86
17
03-20-2007 09:27 PM
vikingsven
10-29-2006 09:28 PM
billygoat02
12-30-2005 10:19 AM
