It's alive again, with TWINS
Old 07-13-2004, 07:04 AM
  #31
Ryan's Avatar
Originally posted by Forrest
What's different now -vs- when you ran the 505/1052?
Only difference is the clutch. Those temps are at the same (505/1052) set up that I dynoed. I just finally got the second temp gauge in so I watch both numbers at the same time.
Old 07-13-2004, 08:54 AM
  #32
PourinDiesel's Avatar
Ryan,
Now that you have a dd clutch, are you going to sledpull with it?
Old 07-13-2004, 09:34 AM
  #33
Ryan's Avatar
Originally posted by PourinDiesel
Ryan,
No Comment.
I do know that there is a pull in Columbus on the 15th.
The truck is not ready to quite yet.
Old 07-13-2004, 12:44 PM
  #34
Good luck gettin into it with twins.
I know a guy that they wouldnt let pull last year, because of twins.
Maybe exhibition?
Old 08-10-2004, 12:59 PM
  #35
Ryan's Avatar
Towing Update
Finally had a chance to put the truck to work this weekend. Drug about 23K around for 300 miles in east central IN. To be on the safe side I backed the box down to 3x3 to see how things went. Max EGTs for the entire trip were 1175. Those came when climbing a long, not real steep grade, on I70 east of Indy. Started at 75 mph at the bottom of the hill and crested at 78 mph, ran at about 40psi boost the entire stretch.
This weekend the box will get turned up a bit to see how that works.
The best part was haveing enough speed at the end of the on ramp to walk away from the PSD with his little 6K trailer trying to get up a hill.
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
thrashingcows
08-23-2010 07:01 AM
maddog madden
01-17-2007 10:16 PM
wtmtnterror
04-26-2005 01:53 PM
Quick Reply: It's alive again, with TWINS
