Isspro guages from diesel manor..
Old 04-08-2007 | 06:54 PM
mx684's Avatar
Im trying to order guages right now and getting kind of confused what all i gotta have....i chose the apiller and gauge kit, for 349...now it appears i need that braided hose...so should i get the braided hose/banjo bolt..42??? then what about this isolater thing for 79? do i need that also??? any help would be greatly appreciated...
Old 04-08-2007 | 07:06 PM
Adam3291's Avatar
No metal hose, no isolator. The kit comes with tubing to plum the fuel into the cab. Way more accurate if you don't use the isolator.
Old 04-08-2007 | 07:32 PM
mx684's Avatar
alright, great..thanks so much.
Old 04-08-2007 | 07:58 PM
66fordcrewcab's Avatar
I just bought there gauge kit. I got mine with out the isolator. Haven't had any problems yet. If you tell them you don't want the isolator it saves you like $80. There kit come with every thing you need to install the gauges and it is not very hard to do. Also they have great customer service, I had a the thing that holds the pyro in to the exhaust manfoild break on me while i was driving down the highway. Called them up they sent me a new piece free of charge with out sasking any questions.
Old 04-08-2007 | 08:07 PM
mx684's Avatar
i was just confused cause it said sumthin about needed a braided line (not included) and a banjo bolt (not included)
Old 04-08-2007 | 08:22 PM
bigredBCS's Avatar
egauges.com!!!!! i believe i quoted them to be cheaper than diesel manor
Old 04-08-2007 | 08:44 PM
P.J's Avatar
P.J
He should sell you a banjo bolt and some washers with the kit.
David at Diesel Manor will match or beat prices, just let him know....
Old 04-08-2007 | 08:46 PM
P.J's Avatar
P.J
You DON'T need a stainless braided line, the "boost" hose that will come with the f/p gauge is rated WELL above the 15 psi you will have on it.
I would recommend going to NAPA and buying 6 feet of 3/16" fuel hose to slide over the f/p gauge tubing, this way it is protected from cuts and kinks.
No biggie.
Old 04-08-2007 | 09:51 PM
mx684's Avatar
alrighty, thanks alot...got them ordered..went with the black ones, i thought those would go better with my factory dash.. should be here this week..
rjm022
04-26-2007 06:11 AM
riata_ag
04-23-2006 11:58 PM
sadlerb_98
23
03-25-2006 09:40 AM
CRXsi
25
03-17-2006 07:40 PM
CTD2001
04-24-2004 09:55 AM
