isspro guage trouble
i am having trouble with the fp guage isolater on my guage kit purchased from diesel manor. installed it and it reads 10 to 12 psi. onstock fp setup and then dies to 0 in like 10 seconds. fp is pumping fine maybe losing air or something enroute to guage help please.
Thats why I went to a mechanical Isspro Gauge 4-1/2 years no problems.
Unhook the tubing fitting at the isolator and push the diaphram back into place. Get as much 50/50 antifreeze into the isolator before reattaching the fitting and filling the tube. Also, mine leaked a tiny bit at the gauge fitting causing the preasure to drop over time as well. Use thread sealer and check for leaks. Mine has been real reliable and consistant since.
02 HO Sixspeed, Edge EZ, AFE intake, gooseneck hitch, roadarmor winch bumper with Milemarker winch.
I had same problems with my isolator for a whole year. I always thought it was a pump in my 2 pump setup so i always switched one out and it was fine. Then i ditched the isolator and ran fuel right to the gauge. Best thing to do imho. I primed my line into a soda bottle and then hooked it up to the gauge and siliconed it. No problems since.
It may take 2 or 3 trys to get enough anitfreeze in the line to get a steady gauge reading, I had to fill my isolator twice. If there is not enough in there eventually all the anitfreeze gets pushed up into the line, leaving the diaphram empty, and since air can be compressed you wind up with low or no pressure reading on the gauge.
thanks
thanks for all the info guys does anyone else have any more ideas or opinions it would be greatly appreciated. I am going to give this to my mech. tomorrow so that maybe we can get it working correctly cause the wife is gettin impatient she wants to go get her bdrm suite and i dont wanna have to pull it with POPs stroker with 270k on it that would just make my CTD look BAD
silverram323
01-05-2004 12:23 PM
Dodgezilla
03-07-2003 01:06 PM
