ISSPRO EV FP Gage Install
WHAT A PAIN!
But, I finally got it installed. Well almost.....I forgot to hook up the light. That can happen later when it's not 100* outside.
I have attached a pic of the 45* fitting I used to keep the hose from having a sharp bend behind the A-pillar. This may be the way everyone does it, but I had to go to five places before found what I was looking for.
CR
CR
CR, where did you get your 45* fitting ? I'm getting ready to do the same thing once my other two gauges get here.
Is that just a regular barb on the hose side? Slide a hose over and put a hose clamp on?
Also, did you use a needle valve off your fuel filter housing ?
Thanks
Thanks
I got the fitting at a supply company in Plano, Texas. I don't remember the name, but I'm going by there tomorrow and I will get it for you. I'm going back by there to get another fitting because I don't like the way the needle valve sits right on the filter housing. No one else has what I'm looking for and I forgot to ask about it the other day. Yes, it's a barb that the hose fits over. I put a plastic tie strap on it.
CR
CR
Here's one of the needle valve. I wanted it to raise a little higher off the cannister, so I used a couple of extra fittings to get it up.
I finally found all the fittings I needed at B.A. Industrial Supply in Plano, Texas.
blackdevil
03-14-2006 11:01 AM
windkid4
08-31-2005 09:44 AM
NavyChief
05-23-2005 09:44 AM
