ISSPRO Cool down timer
I read somewhere the other day that ISSPRO has a cool down timer that you can plug into their EGT gauge, set a desired temp, and when it hits that, it turns the truck off. I haven't been able to find out anything about it and I was wondering if yall knew something. Thanks for the help yall.
Here's the part in the ISSPRO catalog. A little sparse on the information though. http://www.issproinc.com/products.php?cat=124
And one page that describes it.
http://www.dieselpage.com/iss32.htm
All found with Google.
http://www.google.com/search?hl=en&q=isspro+turbo+temp
brandon.
brandon.
They are not the same so comparing price is not really fair. The 80.00 unit goes by time so you have to decide how much time will do the trick based on how hard the engine has been run, outside temps and such where the isspro lets you set a shut down temp to shut off.
Run time will always be different, may be just 30 sec or 3.75 minutes etc. while it looks for the temp to shut down.
I am looking into doing that with my SPA EGT gauge as it can power a relay at any user selected temps, just gotta figure out the wiring.
TripleBquad
13
11-20-2006 02:59 PM
