intercooler boots
intercooler boots
ive been having problems with the boots blowing off. it wasnt bad till i put the injectors in. they blow off every time i stomp on it. i was wondering if the big rig style boots with the wire rings around them would be better with spring loaded clamps.
Take them off and clean them and the piping. There might be some oil residue on them and thats why they are slipping. Piers has a set you can upgrade to if you really want to.
yea i took them off cleanded them clamped them tight as i could get them. first 50 psi they came right off. guess im looking at the piers ones. but do you use the stock clamps or do you use spring loaded ones
Your stock boots were not made to handle 50psi. When I put new boots on I called everyone and PDR was the cheapest and they work. If you order a pair you'll see the differance. They are PITB to put on. If you keep trying to push 50psi through the stock boots you'll eventually just shred them.
I've been running about 57 psi and havent blown mine yet. I sure it will happen at some inopertune time though. Cant wait!
mullishacrew
10-30-2008 09:29 PM
Palmetto_kid
11-13-2003 05:57 PM
Cumminsdieselboy
07-08-2003 12:58 PM
