Intercooler
Old 11-10-2003, 11:43 AM
BigBlue's Avatar
Intercooler
I was just wondering when the stock intercooler becomes a restriction and stops lowering temps and starts to raise them. When does it blow apart (what boost level)? Has anyone blow one? What about an air-to-water aluminum intercooler?
Old 11-10-2003, 06:58 PM
y-knot's Avatar
Re:Intercooler
I don't think the intercooler has the ability to raise temperatures. As long as air is getting to it, and flow is not restricted, it can't heat only cool. The intake temp to the turbo is most of the time, ambient temp. And the intake air will always pick-up heat from it's charge, so it will always be warmer then the air, to air intercooler. A air to water intercooler just isn't practical on a vehicle, a boat yes. The water needs to be turned over, to remove the heat from the exchange, on a boat this could be done fairly easy. In certain race situation they do this. They use cool cans filled with ice, and run the fuel through them for a denser charge. The same basic ideal for the charged air system.
Old 11-10-2003, 09:27 PM
TxDieselKid's Avatar
Re:Intercooler
I have heard of IC's letting go around 90-100 psi of boost, and anywhere on up. Enterprise Engine does have a upgrade over the stock one.
Andrew
92smokin blacky
01-14-2010 09:23 AM
6Stix
02-13-2009 08:32 AM
mullishacrew
10-30-2008 09:29 PM
Marine
02-07-2003 06:32 PM
csaverline
10-23-2002 04:55 PM
Quick Reply: Intercooler
