Interchangable exhaust housings??
Can anyone give me an idea which exhaust housings will fit the HX35w turbo? I know what I need but do not know which ones fit it. Do the early Dodge/Cummins housings fit?
the older 18 and 21cm housings attached to the downpipe with a band clamp where as the 99s are bolted on but an exhaust elbow from a 97 and older uses the band clamp to attach to the down pipe
Thanks guys for the info. I had an opportunity to purchase an elbow for the older models and passed on it.... darn. The turbo that I intend to put it on is also a band clamp turbo. The commercial engines use the old style, so I installed the Dodge turbo and never got around to changing it. Should be an easy change, it only has a couple of thousand miles on it. Now if I could find someone that wanted to swap.... Mine is a 12cmwg bolt in to a first gen.
I finally got all the parts together and have assembled the turbo. Will be installing it in the next couple of days, hx35-18.5 with the turn down for the stock pipe. I will let you know how it works out for economy and any loss of power. Not sure yet if I will have to move the pipe forward or not. Looks like the longer exhaust housing and the shorter elbow will evan out and just bolt up. We will see.
I see you got the Elbow...I'm still trying to find time to put mine back together
I'm glad it finally rained (farm equipment dealer in planting season )
Chris
Chris
Chris yes received it yesterday afternoon. Got rained out, have severe right now, hoping to get a break to hook up and move a load, if not wet time. Remember the weather you get we generally get a day later. I will get with you and settle up over the weekend. Thanks so much, and quick too, wow. It went together easily, so maybe I made the right decisions and the larger housing will do what I think it will. Of course I have never made a mistake
JOE M
12-23-2009 09:32 PM
D.Wiggs
11-28-2006 11:52 PM
